Symposer what dose it do & do we need it
65K views 20 replies 13 participants last post by  scoobboy
#1 ·
i just been flicking around the jwr sponner link and i came across a topic removing the Symposer ?
so now i am thinking what dose it do . some 1 told me that some times u can get a boost leak fron there is the diafram has gone.
so think if i remove it no chance of ever lossing boost from there ?
#2 ·
The symposer carries engine noise into the cabin Lee.
But as you've got a sport exhaust you won't notice it.
Just get a 35mm alloy bung off ebay, remove the symposer and block the hose to it from the Intercooler hardpipe
#21 ·
Jesus mate tell me about it.
I had a nitemare with mine yesterday.
Took the collins dv off no bother bout 5.40pm thinking another 20 mins before it gets dark should leave me plenty of time lol.
When took the hose out the jubilee clip fell off onto the undertray and had to jack car up in dark
The hose was a nitemare to get back on the symposer and intercooler.
Ended up out with a torch holding it between my teeth.
Never again will a dv go back on that car in my ownership.
Much prefer the growl in the cabin now anyway, woohoo.
#6 ·
Air from the pipe in between the throttle body and intercooler is pushed against the the red diaphragm, the little hole on it allows air throw to the grey one and makes it vibrate creating the 5pot noise we all like.
If the grey diaphragm is damaged you'll loose boost.
#12 ·
You would get a ESP light and a P101 fault could showing a MAF error due to the airleak - also you would also hear the leak under load. - To date we have only had two with faulty diaphrams in over 7 years of working on ST's and RS's
#18 ·
I lost my Rumble sound in the cabin so decided to split it. There was a big split in the diaphram! I repaired the split, put it back together and refitted it. I got the cabin noise back by doing this
