Headlights flickering
6.3K views 10 replies 6 participants last post by  Monkeysnutscom123
#1 ·
Okay so both my headlights filcker which I have learnt is normal, however my drivers side light has started to flick on then go off completely. I have checked the connections inside the unit and they look fine, not sure if its time for new lights or not.
Could it be an earthing problem?
Thanks in advance.
#10 ·
What do you mean by "flickering" ???
My ST is the first car I've had with HID units with the (mandatory) self leveling system and on the few occasions I drive in the dark they give an annoying appearance of flickering because, on the appalling roads we have here in rural East Anglia, they are constantly going up and down trying to keep themselves level. Once I'm on a (very rare) smooth "A" road the appearance of "flickering" goes away.
Obviously that doesn't explain one of them now going off completely but it might be what you've seen previously if your roads are as bad as around here.
#11 ·
Ok so a little update guys, it was the bulb that was faulty. Got a set (ordered 2 by accident) and fitted them and they now work perfectly.
Just FYI, the flickering failed an MOT. This was because it was flickering when it was stationary (you can check my MOT, M24TNR). But after a little chat the car passed ;)
