1 - 9 of 9 Posts
Only simple suggestion to check yourself would be the seat connectors - disconnect the battery, wait a couple of minutes then check the plug under each seat - maybe undo the 7mm bolt, undo then remake the connector. you could also check the wires are secure in the back of the plugs, possibly on the seat too if they're visible.
Reconnect seat connectors then reconnect battery and see if fault has cleared.
Anything else i'd say dealer job sadly.
ps after reconnectin your battery you'll need to operate the electric windows up and down a few times for the anti-trap to learn itself again.
1 - 9 of 9 Posts
