Hi
I'm having an issue with one of my high beams. The car is a st3 so bi xenon headlights, I first thought I had a high beam buld out, but in closer inspection discovered that the xenon flap doesn't appear to be lifting, and te buld seems intact, any ideas?
Captain Slow
I had a sticky lens and still do at times............it's SO intermittent on my car. 99 times out of 100 it is OK!
If you flash the lights a few times does it drop?
I thankfully have a new replacement headlight to (eventually) get round to fitting.
Thanks for the help, problem solved now, it was the fuse, each full beam is fused separately, hopefully this will help someone else.
