Hi all, I am starting a group buy thread for the Wavetrac Diff.
will be some time yet before any can be ready but getting started and I hope some of the forum sponsors can get on board to help supply and fit these diffs around the country.
for those of you that don't know about the Wavetrac Diff it is like a cross between a geared diff eg Quaife ATB and a plated diff
but with the benefits of both. Eu4n explained it well in a different thread:
Minimum order is 10 units and the larger the number the greater the discount.
Those interested
1 - Doodlemcdoo (focusstoc & focusrsoc)
2 - Jacques (focusstoc)
3 - Kev. (focusrsoc)
4 - Eu4n (focusstoc)
5 - Monkeytrousers (focusrsoc)
6 - J114YER (focusrsoc)
7 - Scoop (focusrsoc)
8 - Loops (focusstoc)
9 - 2bar (focusstoc)
10 - Tim Warren (focusstoc)
I will add prices once I get confirmation from Wavetrac to buy direct so at the moment its to see who is interested and confirm orders later.[background=rgb(236, 236, 236)]A Quaife differential [/background]is[background=rgb(236, 236, 236)] 'fit and forget'[/background]
[background=rgb(236, 236, 236)]A Wavetrac differential [/background]is[background=rgb(236, 236, 236)] 'fit and forget'[/background]
[background=rgb(236, 236, 236)]A plated diff [/background]isn't[background=rgb(236, 236, 236)] 'fit and forget'[/background]
[background=rgb(236, 236, 236)]A Wavetrac is like a Quaife but with more benefits of a plated diff (think of it as between a Quaife and plated diff). For example it works in a 'zero torque' situation where one wheel has zero grip, in this situation a Quaife wouldn't transfer drive to the gripping wheel but would spin the wheel with no grip. The Wavetrac can deal with 'zero torque' situations like this and would still be able to transfer drive to the wheel with grip.[/background]
[background=rgb(236, 236, 236)]The Wavetrac site explains it very well: [/background]http://www.wavetrac.net/technical.htm
[background=rgb(236, 236, 236)]Think of it this way: you have one wheel on ice and the other on tarmac, the wheel on ice has no grip and is spinning.[/background]
[background=rgb(236, 236, 236)]With a Quaife diff you're stuck, because once wheel has zero grip it can't send drive to the gripping wheel.[/background]
[background=rgb(236, 236, 236)]With a Wavetrac diff you're going to get traction and be able to move off. The Wavetrac can deal with once wheel with zero grip and still transfer drive to the gripping wheel. A Quaife can't do this.[/background]
Those interested
