1 - 10 of 10 Posts
hey guys,
really odd issue...
So all washer jets work,
Rear - Fine
Headlights - Fine
Drivers side - Fine
Passenger - Dribble
So i have checked all the lines and jets etc all ok.
the pressure at the drivers side pipe is strong but weak at the passenger side (washer jet disconnected)
So im a bit lost as it cant be the pump in my mind as everything works but the pressure to passenger side almost doesnt exist....
anyone got any ideas?
thanks
you will probably find that there is a piece of plastic that joins the drivers side pipe to the passenger side and that its likely clogged up slightly (as its narrower than the piping).
it could also be that the pipe itself has got a small blockage in it too.
I blew through them all of that and seemed fine....
im gonna try a plan of missing the first washer jet to confirm if that is stealing the pressure... it wont confirm much apart from no blocks .
any one had this? got some more advice/things to try
update, no blockage at all.... so appears the pump isnt giving enough pressure?
is this a sign of the pump going or the filter being clogged?
Captain Slow
If you're getting a decent flow out of the rest of the washer jets I would have thought the pump was working OK
They are mist ones....
The pressure past the first washer jet isn't great
but nothing is blocked
Very confused
Not that I can see, no lose of fluids and no drips.....
It's only recently turned like this..... Gonna stip the wheel liner out and investigate more but i can't anyone with similar issues of good pressure and one weak when its not the washerjet as mines fine and tried it on the good side
1 - 10 of 10 Posts
