Formerly known as wabbit1
Hi all,
need someone who's mechanically minded to help me sort my Fianceés StreetKa.
The car is a completely standard 53 plate and has covered 35000 careful miles in it's life.
The problem started today when she was driving it home from work. Stopped at a set of lights feet on the brake and clutch the engine, rather than idling smoothly moved from 900 - 1200 rpm in a pulsating rhythm, up down, up down. It stopped when she pumped the brake pedal but soon started at the next stop
When driving after this the engine felt like was stuttering a bit, nothing major but you can definately feel it.
If anyone who's in the know about things like this I would appreciate and advice or suggestions.
Many thanks guys
QUOTE(wabbit1 @ 20 Jan 2010, 09:01 PM) <{POST_SNAPBACK}>Hi all,
Many thanks guys
1 female owner and 35000 miles hmmm check the air filter as it may be gasping for breath
Am taking it that its the 1.3 8v OHV engine thats in it?
If it is, try a blocked breather, or a burst vacuum hose.
Other than that, check for the last service, could possibly be a blocked air or fuel filter (but i doubt it) if all that fails then you will be looking for component failure, if thats the case than get it code read, looking for current and intemittent fault codes.
Hope this helps mate.
QUOTE(goonturbo @ 20 Jan 2010, 09:30 PM) <{POST_SNAPBACK}>Am taking it that its the 1.3 8v OHV engine thats in it?
It's got the 1.6 8v DuraTEC engine in it.
I'll give the breather and vacuum pipes a check tomorrow in day light and see how that goes.
If not I'll get a local garage to check any error code
Graham - mk2 stage 3
If she had her foot on the brake and there is a leak in the brake servo pipework, or the non-return valve it might have let air leak into the inlet manifold and cause the uneven idling. It could also affect the car when driving on a light throttle.
Sticking ISCV(Idle speed control valve). From what I remember the are a pain to get to on the ROCAM engine. 2x 8mm Bolts hold it on to the inlet manifold. Could just need a clean out with Brake cleaner or similar.
Dont take this a gospel. Been 6 years since worked at a Ford garage.
