1 - 20 of 21 Posts
I'm posting this here as its ice related I suppose, feel free to move it to appropriate section .
Sync will not play iPod , message says USB drive error , so I started BT streaming from iPhone and it was fine until I stopped to fill up , got back in and now it won't stream either .
Every thing else works fine , had this happen a while back and had software update done at fords and its been fine since then .
In the menu there is a sync reset , but I'm not sure wether to try it as I'm not sure what it will do and I might lose the emergency assist that was added , any ideas would be appreciated as I don t want another trip to fords
Cheers in advance
Just a thought. Is it because its got 5 doors LOL
2019 AMG C43
Lol @ 5 doors
I don't use iAnything so can't help I'm afraid. I've got a USB stick and a Windows Phone 7 phone, all works lovely
I'm also not sure what the reset does, at a guess I'd say it does a factory reset - whether that will lose any upgrades or not is an unknown. Sorry I couldn't be of more help!
I have had problems , with iPod sync, sometimes I can get in it won't work, other times it won't let me change track, lately every time I get in it always says track 1 , sometimes I unplug and reset iPod , might work for a bit. Is there a limit on songs u can have as I have now got an iPod classic??
Lol @ 5 doors
Cheers Sean ,
With the USB stick do you get track info ETC as I might just get one of them
2019 AMG C43
I don't think there's a limit on songs, but after a large number of tracks it'll tell you that you can't pick a track by name using voice. That's because it runs out of 'grammar', the number of words it will recognise.
Cheers Sean ,
You will get track info with the USB stick as long as the MP3 tags are set correctly, because that's where Sync gets the info.
No idea on the ipod situation or the sync reset, most sync info is online but you should be able to check the emergency assist option via the H.U.
press the phone button & when you scroll down you should have an emergency assistance option that you could enable/disable. Not sure how it could have been 'added' as a later feature.
2019 AMG C43
It was added as an upgrade to Gary's and Kev's cars as they had really early cars with a slightly older version of Sync. A couple of others had to get the upgrade too.
I've just done a quick google and found a post which mentions all USB problems and he pulled the fuse and waited 30 seconds
All,soughted
May lose settings but what do you reckon
Discussion Starter · #13 ·
All,soughted
Had a look today and found 2 fuses with audio on them ,nothing with sync, was about to pull fuses ten had a thought about radio code
Nothing in the handbook and no code card , so thought I'd give rates a call and spoke to a tech there who confirmed these radios don't have a code ,and pulling the fuse is 1 of the methods they use to reboot the system , he said pull and wait 30 mins for it to power down .
So will try tomorrow
I tried the reset and all it did was to clear the bonded phone , didn't change any settings at all
2019 AMG C43
So much for the reset being scary then lol. Let us know what happens when you pull the fuse, assuming the world doesn't end as a result...
Discussion Starter · #15 ·
Pulled the fuse today left it for 30 minutes and replaced it
Still getting the same issues , but all the settings remained the same as if the-power hadn't been disconnected .
I did try to turn the radio on to check it was the correct fuse and it wouldn't come on , perhaps might have to leave it longer
2019 AMG C43
I sometimes get my android phone to work with sync but many times it doesnt, my conclusion is that sync is just rubbish!
Just because your phone doesn't work with it? That's a bit harsh. My phone works perfectly with it - finally there's a benefit to owning a Windows phone
Its not harsh, its a fact, my phone is a Samsung Galaxy S2, does that mean that Sync doesnt work with Android? Besides ive been getting a bunch of problems with sync, for example if I turn on the AC, sync automatically starts playing whats on my usb drive; when I make a phone call first, sync wont turn on the AC later. Dont know if you are having the same issues in the UK, but if I could have the option of saving some money I would buy my ST without Sync.
2019 AMG C43
I'd say there are some issues with your Sync....the USB shouldn't affect the A/C and vice versa. And as far as I'm aware the S2's in the UK work fine with it. I'd have a word with your dealer.
1 - 20 of 21 Posts
