Strobe Brake light?
1 reading
1.8K views 20 replies 12 participants last post by  Granite
#1 ·
Is it legal?
I'm looking at a brake light that will flash upon braking 3 times then have a solid light.
Just wanting to know whether this is legal or not?
I know some on the new mercs have strobe lights if they have slammed on the brakes and they act as hazards. Just want it clearing up before I spend some money!
#2 ·
European regulations cover it:
E/ECE/324 E/ECE/TRANS/505, Addendum 47, Regulation No. 48, Revision 6, dated June 2010.
2.28. "Emergency stop signal" means a signal to indicate to other road users to the rear of the vehicle that a high retardation force has been applied to the vehicle relative to the prevailing road conditions.
Further investigation reveals that details for the systems are laid out as follows.
6.23. EMERGENCY STOP SIGNAL
6.23.1. Presence
Optional
The emergency stop signal shall be given by the simultaneous operation of all the stop or direction-indicator lamps fitted as described in paragraph 6.22.7.
[followed by details as to the position and number of the lights]
6.23.7.1. All the lamps of the emergency stop signal shall flash in phase at a frequency of 4.0 ± 1.0 Hz.
6.23.7.1.1. However, if any of the lamps of the emergency stop signal to the rear of the vehicle use filament light sources the frequency shall be 4.0 +0.0/-1.0 Hz.
6.23.7.2. The emergency stop signal shall operate independently of other lamps.
6.23.7.3. The emergency stop signal shall be activated and deactivated automatically.
6.23.7.3.1. The emergency stop signal shall be activated only when the vehicle speed is above 50 km/h and the braking system is providing the emergency braking logic signal defined in Regulations Nos. 13 and 13-H.
6.23.7.3.2. The emergency stop signal shall be automatically deactivated if the emergency braking logic signal as defined in Regulations Nos. 13 and 13-H is no longer provided or if the hazard warning signal is activated.
#12 ·
^ This.
It's not legal...so just accept it and move on. Don't try and wangle around it by finding out if the punishment for fitting it is low enough to warrant fitting one.
If I saw someones 3rd brake light flashing like that and the other 2 just solid red light...I would just assume they had an electrical fault with the car.
Completely pointless.
#21 ·
Brake lights will flash in an emergency braking situation
If the brake lights were to strobe under MOT conditions, they would fail as the are operating in a manner that they are not designed to. The brake lamps should illuminate for the period that the pedal is pressed.
Would look anyway, and would serve much of a purpose
