1 - 9 of 9 Posts
Hey guys
wierd one, done this 5/6 times in the last 6 weeks or so.
Brake warning light illuminates, at the same time outside air temp disapears with ----- and the indicators work, but no tell tale at all. 2 mins later and warning light disapears and all is fine. Ive not had my scanner on it, nor checked any charge rates etc, and its not just low brake fluid as ive checked, anyone came across this ? Blo0dy cars !!
Be nice if its just a battery with a dead cell. I'll have to drop test it, & check those connections. Thanks boys.
Drop tested battery. Wasn't the greatest, proper Bosch battery fitted, and still the flaming same
I take it that's the fuse box etc in the footwell, as this was also checked out while the battery was disconnected.
Yes, that's the one.
Loose connections are not uncommon (sometimes gets a kick from the passenger
You could also run the GEM diagnostic (see the "how to" section for details)
Yeah, it's a fault on sprinters, people pull the feed to the injectors lol
I'll have a nosey, thanks for your assistance buddy
1 - 9 of 9 Posts
