Morning all,
I've notice something happening in that last couple of days and wanted to ask about it as i'm not that techy with cars. Got a 09 plarte facelift with a standard clutch. the clutch works normally but if a finish a journey turn eginer off etc etc then use the car again within 20 minutes the clutch is noticably harder to use. and it stays thay way for the journey, is doesn't losen up, or anything. for example drove from work to pickup boy from nursery, trip was about 15 miles, clutch fine. went into nursery picked himup, spoke to staff etc etc cam out 10 minutes later to a harder clutch.
Again last night got home from work, clutch fine, the missu used the car to goto the shops, then went out 20 mins later to watch batman (very good!
) and on the trip the the cinema the clutch was stiff, but came out of cinema 3 hours later and the clutch was fine again.
Its still usable but it is definately harder to press.
As anyone seen this before, or knows what it could be? i'm guessing the clutch is hydrolic, and that would tend to indicate some kind of fluid issue, but if the car sits and cools down its fine.
