1 - 3 of 3 Posts
I just got the Ford stuff from the dealer. The reservoir is at the front left hand side of the engine bay.
There are max and min level marks on the side of the reservoir (see the pic in the owners guide if you can't find them).
It's worth noting that the normal level does appear quite low when viewed from above so there's a good chance it doesn't actually need topping up anyway.
The system doesn't consume fluid so if the level has dropped you probably have a leak.
QUOTE(Alb @ 9 Jan 2010, 02:16 PM) <{POST_SNAPBACK}>I just got the Ford stuff from the dealer. The reservoir is at the front left hand side of the engine bay.
ok cheers.if its leaking it can go back to fords to sort
1 - 3 of 3 Posts
