I'm having a nightmare here. I bought a focus st 250 in October and put 4975 miles on it when it completely s*** itself 3 weeks ago. The engine Is seized.
The car was clearly highly modified and was not advertised as such.
It's on a bad credit finance deal through billing finance at 240 quid a month for the next 5 years.
Obviously I'm fighting it under consumer rights as I only had it 3 months when this happened..
The finance company sent out an engineer who only took the plastic engine cover off , checked the dipstick and just took photos then read the engine codes..
I've now had their final decision that states ,from the report :
"There was no breach of the engine crankcase that would account for a sudden loss of oil, leading us to the conclusion that the vehicle has been run with insufficient oil in the sump and insufficient coolant, this has caused the vehicle to run at elevated temperatures and induced engine seizure"
They are closing the complaint and blaming me for lack of maintenance..
This guy just looked at the car on the street. Am I wrong in thinking here there is no way he can properly tell if there's a cracked block or blown gasket by visually looking at the top of the engine. Didn't have the car up to look underneath with tray off.
I did check the levels regularly and all were fine. The car was burning alot of oil.. 2 litres in the space I'd had it and that's why I was checking it regularly . What ever has happened has caused all the coolant and oil to drain out. .. big puddle of oil under her at the recovery yard the next day which sadly I didn't take photos of.
Questions.. what Could cause all the coolant and oil to come out in one event?
And, Do I have a leg to stand on here.. are they trying to play me?
Surely the engine needs taken out to inspect it properly? How can he say a pump didn't fail ?
I'll add I hadn't checked the oil in a week or so but no oil light warning came on. Could the engine have burned itself dry of oil so fast with no warning?
And also a few days prior to this I had the engine light come on briefly but then went off again ...which the engineer said the code was a misfire in cylinder 1. I can't help but think this was heavily involved?
