1 - 15 of 15 Posts
Ok a weird thing with my ST today.
The car feels very jelly like today in the bends. And when I brake a little it sort of lunges forward on the suspension. very odd!
I've rocked the car on above each wheel, seems ok! Although I think I can push the front down a bit too easy! Although I have been doing weight training for the last 3 months, so it could be that lol
Anyone have any ideas?
QUOTE(Trist @ 1 Feb 2010, 08:11 PM) <{POST_SNAPBACK}>Ok a weird thing with my ST today.
See your GP he may diagnose worn shockers. Don't know if they can be done on the NHS though. If your shockers are fine then a course of Eibach's usually remedy those symptoms, take one every 30 minutes (max of 4 in a 24hr period) Oh and finish the course lol
Checked the pressures on the way home, they seemed fine. The rears was a bit low at 29ish, I pumped them up to 33 and it did seem better.
Can I take the ST to like ATS for an alignment? I know when I had my VXR they couldn't do it!
FocusSTOC Nut&#33;
QUOTE(Trist @ 2 Feb 2010, 06:09 PM) <{POST_SNAPBACK}>Still the same today. Beginning to think it's the tyres. Got these up front http://www.eptyres.com/detil_products.php?...ccelera40Series
And I think theyre causing the problems.
I cant think how anything mechanical could go wrong while the car was sat on the drive all weekend!
i had a set of these in 20" flavour, on my bmw 330d mate and they were very entertaining to say the least.
Their really weird tyres, you get a sweet spot for a few thousand miles and then they just go all funny. Their much better on the ST than my VXR though, the VXR was dangerous with them on! Got the ST and VXR from the same dealer, seems their getting these tyres really cheap.
I've got nearly 1mm before the wear marks on the rear contis. And got about 5mm on the the above tyres up front. So I'm going to change to the Verds or Falkens all round soon. So. I hope it improves.
Any tests or things I can look out for to find any mechanical problems on the car?
FocusSTOC Nut&#33;
switch your wheels around mate & put the conti's on the front, see if it helps. could also be an arb bushing. best get it up on a ramp & get them all checked. did you have real cold weather over the weekend? i found with these cheap tyres the rubber is very poor quality & does'nt like frost!
Discussion Starter · #12 ·
It froze saturday night, but nothing bad. It's been worse just before xmas.
I might do that swapping them round.
I'll check the arb and stuff.
mine felt horrible with cheap tyres - got bridgestones now they truely do stick to the road, the ESP hardly activates either.
never get much said on the forum about them but i would defo have them again.
1 - 15 of 15 Posts
