1 - 12 of 12 Posts
Hey all
Does anyone know where I can get the spacer, which goes between the standard airbox and the engine? I've seen it before and is meant to aid heat soak.
Can anyone help?
Martin
FocusSTOC Nut!
QUOTE(Martiy @ 15 Feb 2010, 09:44 PM) <{POST_SNAPBACK}>Hey all
Can anyone help?
Martin
if your talking about the ecu spacer. to move it forward and get more power, you get them on ebay mate.
usually about £30 iirc.
Can anyone help?
Martin
pm jabbos on here £30 that includes p&p great mod
No you just pull up the ecu cover, and undo 4 screws securing the ecu to the airbox, just move the ecu to the side to allow you to put the spacer in place than put the ecu over it and use the loger screws back in.
DO NOT remove the plug off the ECU
Did you have to modify your ecu cover after fitting your spacer?
QUOTE(bully09 @ 16 Feb 2010, 08:27 AM) <{POST_SNAPBACK}>pm jabbos on here £30 that includes p&p great modHi mate.Just received my ecu spacer. Did you modify your ecu cover?QUOTE(bully09 @ 16 Feb 2010, 08:27 AM) <{POST_SNAPBACK}>pm jabbos on here £30 that includes p&p great mod
1 - 12 of 12 Posts
