· Registered
Last week i ordered a snow foam lance from cleanyourcar.co.uk, today i went to try out my new toy but couldnt get attached to my gun. I'm using a Karcher 6.91 and i ordered the lance with the karcher fitting but it just wont go on. Anyone else had this problem? its deffinetly not just a tight fit becuase if i push down any harder i'd brake either the gun or the lance.
its got me a bit baffled because to look at its exactly the same size and shape as my standard karcher attachments, but when you try to put it on it only goes in so far and wont go down enough for me to twist and lock on.
is there a new type of gun that these are meant for?
· Registered
QUOTE(Trist @ 5 Dec 2009, 10:23 PM) <{POST_SNAPBACK}>You got the metal connector?
There are issues with the metal connector ones. Mines the same, a right
to put on.
Autobrite brought out this connector which is supposed to fix the problem
http://shop.autobritedirect.co.uk/autobrit...ector-333-p.asp
yeah i had seen that about the brass ones but mines the "new" plastic style connector but still have a problem with it
· Registered
Right Fixed it! On the inside of the attachment there was a plastic lip, probably to do with when it was manufactured. This was stopping it form going all the way down, filled it back and now it goes on and off easy peasy!
Russ
· Registered
good man now go spray that creamy load all over your car and give it a good hosing down after letting it sit for 10good man now go spray that creamy load all over your car and give it a good hosing down after letting it sit for 10
