2006 mk2 5 door pfl in performance blue, Collins CP2
Looks much better, I see so many pfl st's and wonder why they let them out of factory like that.
Discussion Starter · #5 · (Edited)
The bonnet level is a few mm lower than the lights, but a small price to pay and not really noticeable, I followed the advice form a user TurboGT over on focusst.org, you remove the bonnet catch, there are two 5mm holes that locate on pegs and two 8mm fixing holes, which need to be filled with weld, then ground flat, then new holes need to be drilled 4mm higher than the originals, then the bonnet support rubbers need to be screwed down a few turns, until the bonnet closes properly.
Automotive tire Gear Motor vehicle Insect Fastener
Jaw Wood Sculpture Art Automotive tire
