Hi
After some advice because I’m completely stumped for the past year I’ve been running dreamscience Txx map with a full turbo back system from Milltek with no issues whatsoever however a couple months ago I changed the exhaust for something a bit louder went with a Kms thunderstorm only issue I’m having is when the car is running at idle say if you’re parked at a traffic lights or something for a few minutes the car goes into limp mode and you only notice it after you drive away if I clear the code it does come back after a while but only at idle when car is moving it’s fine no issue at all the mechanic thinks it seems to be an issue with the map but if that was the case surely it would of happened on the Milltek system so any advice is appreciated
