1 - 18 of 18 Posts
Focus 2008 (+)"GB" 2.5L Duratec-RS (305PS)
Clutch Kit (Cover & Plate)
Part Number: 1670062
Retail Price: £143.25
You Pay: £114.60
Clutch Slave Cylinder & Bearing Hub Assy
Part Number: 1599267
Retail Price: £84.22
You Pay: £67.38
is this all i need to order...or is there more?
QUOTE(Thunder#59 @ 25 Nov 2009, 10:29 PM) <{POST_SNAPBACK}>Focus 2008 (+)"GB" 2.5L Duratec-RS (305PS)
You Pay: £114.60
You Pay: £67.38
All you need is the clutch plate and cover.
Others may have changed their slave cylinder, I don't know why, perhaps they could advise the reasons why it was necessary.
QUOTE(Tall Person @ 25 Nov 2009, 11:08 PM) <{POST_SNAPBACK}>All you need is the clutch plate and cover.
Because it costs
all to replace it at the time but a lot more if it goes in the future!
PS you also need the Dual Mass Flywheel!
You Pay: £114.60
You Pay: £67.38
yes you might aswell get the rs flywheel too 1575135
The standard flywheel is a dual mass as well, this helps to maintain not only a smoother idle but also helps you to pull away and a much smoother "engine brake". The ones on the early ST's were known to fail after time and the spring mechanisms within the dual mass has excessive play. The RS flywheel has stronger springs and a slightly different design to prevent this.
Discussion Starter · #15 ·
ok, so it went in today
we were prepared to buy the DMF if it was necesary, but didnt order it in case it was only the clutch suffering
guess what......
the clutch wasnt slipping at all!!!
it was the flywheel all along...
it gets better.......
my car already has an RS clutch on it!!!!!
and it looks as though its only done 1K miles!!!!
it would seem that it was playing up for the last owner, so when he/she uprated to an RS clutch....and it didnt solve the problem, they must have traded it in, out of despair!!!
so
my DMF is coming on friday, then we can get it all back on and get that car mapped once and for all!!!
Discussion Starter · #17 ·
www.fordpartsuk.com
DMS is coming from ford as i cant wait for online postage to get the car done
its £320+V.A.T. from ford....not sure if online is discounted like the clutch was
QUOTE(Thunder#59 @ 9 Dec 2009, 08:17 PM) <{POST_SNAPBACK}>www.fordpartsuk.com
Cheers ill go and have a look on there site
1 - 18 of 18 Posts
