just noticed reverse light is out changed bulb but still not working cant be fuse as one fuse no 53 controls all the lights on one side of the car and the rest are on any ideas before i get it booked in under warranty??
Graham - mk2 stage 3
I think the reversing light would be fused independently from the sidelights and headlights. Make sure you have checked the right fuse.
Does the rear wiper work when you have the front wipers switched on and you select reverse?
If not, it is either the fuse or the switch, or maybe the contacts going into the switch not making proper contact. Might be worth giving the wires a wiggle where they connect to the switch.
read the next page in manual there is a seperate fuse for reversing light will check it once i can get the wife out of the car long enough
Got wife top turn wipers on and select reverse and no rear wiper came on, I am gonna try the fuse tomorrow if no joy then i will have to put it into ford to find out if it is the reverse switch on the gearbox.
