· Registered
So my mk4.5 ST went back to Ford for a replacement media screen, I’m starting to doubt if they actually did change it, as the same fault has come back again, question I’ve got when I picked the car up, the screen still had my phone linked to it & all the settings were the same, does the screen store that information or somewhere else in the car? I was expecting it to be back to factory setting?
· Registered
What problem did you have? I get the checkered board sometimes. Once it got really bad and I couldn't use the screen at all. Had to turn off the car and wait several hours.
I suspect its software related over hardware
· Registered
Mk4 ST280
The APIM stores your phone bluetooth and other settings, it's a separate module to the display.
It also wouldn't surprise me if it's the APIM causing the checkerboarding, hopefully it's something they can fix in software.
· Registered
I’ve had two software updates which didn’t fix it, a new screen, they have now changed a module which they say has definitely fixed it, I haven’t tested it yet because it’s still at the dealer awaiting the headlight fix :(
