I’ve got a whistling recirc valve on very lite throttle (about 70mph), I’d like to to know where does it whistle from is there a vent pipe or something or is it an internal noise
ST225 - CP340
It'll be from the diaphram inside most likely (though someone with more knowledge will advise better no doubt :D) . Totally normal though for the stock valve
Mike Mk2 ST225
where does the small rubber hose coming off lead too
I believe it goes up over the engine to the underside of the plenum.
That whistle is why some people upgrade- and once I upgraded I got a little bit of turbo flutter- sounds cooler but is technically worse for the car
