Rear Numberplate Bulb Coluor?
251 Views 7 Replies 3 Participants Last post by  SVMark
Does the number plate light need to be white by law or can i fit a red one?
Just a thought.
No worries - saves you getting pulled
If you want to change the standard yellowy bulbs you could try these :
http://www.ultraleds.co.uk/501194t10-mini-...ulb-p-1545.html
Have started changing quite a few bulbs to LED's on my RS and these look great on the numberplate.
HTH
Andy
Cheers bud,order put in should recieve in about 3 weeks with the
christmas post as it is
QUOTE(kaijack @ 20 Dec 2009, 05:35 PM) <{POST_SNAPBACK}>Cheers bud,order put in should recieve in about 3 weeks with the
Just thought, these 501 type LED's are fitted to the facelift ST and you'll need two. I know these are ok for the 08 facelift ST 'cos I had one. Mine only took two days to come and that was last week.
I think the pre-facelift is the festoon type bulb so best do a search if you need those.
Hope it hasn't caused you any hassle.
Will check-order allready in so if feston will wait till after crimbo to order again-cheers anyway
these one are better for the facelift http://www.ultraleds.co.uk/501194t10-mini-...ite-p-1942.html
I had the others but these are just brighter and look better
