Sorry rear shocks it starts from lo speeds feels like buckled wheel then gets gradually worseWelcome to the club
The car doesn't have rear struts. Are you thinking of something else?
At what speeds do you get the vibration?
Which tyres are you running?
If their Hong Kong skid a longs then this won't help
Lansail tyres think that would be the problem they where ok when first onIf their Hong Kong skid a longs then this won't help
I'm due new shortly hopefully rules it out would it not show up when balancing is being done?I was thinking along the lines of uneven wear like the good years when they wear
Sounds about right they seem to like expensive stuff its never endingPersonally (and I'm not being snobby or picky) but when it comes to these cars you needs good premium tyre not only for grip but wear and low road noise where possible
In theory if one side has worn more than the other you could balance out the weight difference but I doubt it would make much difference to the feel of driving on a wheel that's not entirely circle- or slightly buckled is the same logic.I'm due new shortly hopefully rules it out would it not show up when balancing is being done?
Tried swapping doesn't feel any better same tyres all roundWhat are the fronts like you could swap front to rear see if it helps
I think il replace tyres I have tried front to back but doesn't seem to make any difference and I've no play in wheel bearings eitherIn theory if one side has worn more than the other you could balance out the weight difference but I doubt it would make much difference to the feel of driving on a wheel that's not entirely circle- or slightly buckled is the same logic.
Moving wheels around would be a good start to rule all that sort of stuff out. There's not actually that much at the back end of our cars so shouldn't be too hard to track down
Yea I've had wheel alignment done in 3 places I had rear bushes checked but will get someone else to check bushesHave you had the wheel alignment checked? Also check the bushes in the rear end as they can go soft and come away from the arms.
