· Registered
If you can find out the original supplying garage when the car was new they should have the radio code on there computer files,
Other than that you may find that your local auto electrician can get the code for you or recode the radio.
Failing that then its ford am afraid for which they charge
· Registered
QUOTE(goonturbo @ 5 Jan 2010, 10:35 PM) <{POST_SNAPBACK}>If you can find out the original supplying garage when the car was new they should have the radio code on there computer files,
I'll do a bit of research then, id much rather go an independant place than ford.....but if all else fails.....
