1 - 20 of 20 Posts
· Registered
I've fitted my new quckshift and also the aluminum cable ends. Reset it in 4th and everything seemed fine initially. A rapid gear change from 2nd to 3rd and the lever extended beyond the quckshift range back to almost its original position.... Anyone experienced this or any ideas? It seems I can 'force' it beyond 1st, 3rd and 5th?
· Registered
Ive seen quite a few posts on an American site, where people have had problems with several different manufacturers quick shift kits, Ive come to the conclusion its probably best to stick to stock.
· Registered
Okay, when I have time tomorrow I'm going to refit the original shifter back on to see what it's like with the aluminum bushings.
The effort it is taking to pull it out of gear completely negates any benefit from the shorter shift but having done the bushes and the quickshift at the same time I'm not sure what the issue is....so far it could be...
The quickshift
The cable bushes screwed on too tight (I'll loosen them and apply more grease tomorrow)
The slight rise in height of the cables (yes I've done the additional washers under the boost pipe)
I believe the mountune quickshift places the cable at the correct height and doesn't require the washer trick on the boost pipe so that may be the route I end up going down. In which case there will be a pumaspeed quickshift for sale....
· Registered
Discussion Starter · #14 ·
Nope, that's the modifying game..... pumaspeed shifter is getting changed for the mountune shifter which retains stock height for cable attachment so no issue with the boost pipe. The garage can fit the solid bracket bushings at the same time as new cables....
· Registered
The Pumaspeed Quickshift lasted less than 24hrs in my diesel. I decided that doing a hill start without 1st, 3rd and 5th with traffic behind me wasn't something I was prepared to live with. Fitted the solid ends to the gearbox end bushes instead.
· Registered
Discussion Starter · #16 ·
The Pumaspeed Quickshift lasted less than 24hrs in my diesel. I decided that doing a hill start without 1st, 3rd and 5th with traffic behind me wasnt something I was prepared to live with. Fitted the solid ends to the gearbox end bushes instead.
That's why I'm preparing for the new cables with the mountune quckshift which retains the standard cable attachment height. Not sure why other companies don't maintain this as standard, should be easy if it's cad from billet..... Live and learn...
· Registered
Noticed on the ST i have just bought it already had he mountune short shifter fitted and its a nice tight gear change ,my son has a standard 1.5 diesel focus and you can definitely appreciate the difference, i think its a worthwhile mod.
1 - 20 of 20 Posts
