Hello all,
I have had my st for around six years and have done a few bits here and there but recently (last year) I decided to take on the challenge of having a subwoofer in the boot but unlike just buying a box I wanted a custom box that would fit in the spare alloy to retain my much needed shopping bag space.
I started with the urge to put a 12inch in but unfortunately the space required to fit a sealed box was way to small in the wheel so then had to do many weeks of research just to figure out the best shape and volume to fit a 10inch, luckily there was enough room 0.92 cubic feet of internal box space and just enough clearance for the sub.
I also decided to change the head unit for a cheapy, only to have rca output's in order to run an amplifier. I bought a used active subwoofer and stripped it down in order to make it fit the way I wanted.
Anyway I hope you enjoy my little build and perhaps it gives you some inspiration.
The space I had to work with
The building of the box
I used tightbond 2 to glue all the wood and in-between the gaps a mixture of sawdust and the glue
Yep cheapy audio
Smoothed out the inside
Finished the internal space after painting it
After fitting the amp and sub I was deeply unhappy with the sound and also was slightly concerned over taking up some of the internal volume which is a premium, so I decided to seal the amp hole and build a mini amp rack separately.
Unfortunately I do not have any pictures of that part of the build so all I can show you is the final result using a second hand Edge active sub that I stripped apart and used instead of the extremely poor generic active sub. At the time I was on an limited budget and also didn't know if my calculations were accurate to warrant spending a lot on an amp and sub so this was all a test of engineering and my limited skill
The sound was good and I was enjoying the setup until my longing for the original head unit started creeping in. Now I feel I need to give you all some context I'm an older gentleman and very much old school when it comes to my audio media, I love making my own cd's and I dearly missed my factory 6cd unit and the way it looks and the whole tactile experience and I have no love for touch screens in cars, however this longing was not enough for me to do anything about it until the amp died around Christmas I believe, not entirely sure as to when due only driving bowser every now and then.
This now brings us to the current build, I knew I wanted the factory unit back in and also a complete revision of the amp/sub setup as I felt the box was far better than the two subs could get out of it and with some sort of line out converter for the stock head unit, all in a nice package that did not intrude into my limited shopping bag space.
I went about making a template to see where things would fit
A dry fit
Design changed due to the limited space
Making a bracket that can be removed for the line out converter
Making sure there are gaps all around for the carpet to fit snuggly
The new dvc ground zero sub and the little mono vibe powering it. Hindsight I think the amp is ever so slightly underpowering it but hey, it is what it is
Running all the new cables, what a pain in the :censored:
After downloading test tones and setting up all the voltages from the lc2i and on the amp outputs I connected the speakers, and blew the nearside front and rear factory components smoke and everything.
Back to the online store to get some new speakers then
I was looking online for a company that would sell a package of front and rear components like the factory ones but alas I couldn't find one so decided to just get them separately and also having difficulty in finding the correct mounting brackets for my new components so I went about doing it my way instead
Old blown tweeter
Little bit of araldite
Stripped the new tweeter apart to fit in the existing space
I wanted to retain the factory speaker mounts (riveted in) so cut the desired amount off the face and mounted the new speakers to them. I drilled out the original speaker plug to run the new speaker cabling through it and spent quite a while to find the best place to mount the crossover box
I also made a mistake on some new badges which is part of another project on Bowser that will be in a different post once I'm finished so I decided to use them on the amp rack instead
You can see the black through them, only noticed it once I had lacquered them and although they were a test piece I couldn't be bothered to sand them down again
IMG_20210531_173303.jpg .
unfortunately I don't have any pictures of the rear but they are pretty much the same
All in and tested (nothing blown) and I have to say I am pretty pleased with the sound, the new sub is certainly getting the most of the box now.
Anyway hope you all have enjoyed the journey I have for the most part
Discussion Starter · #2 ·
If anyone wants any further information or just some limited advice from my humble abilities I'm more than happy to assist.
Looks bob on that mate. When I had a sub (not sure if you've already thought of this) I used a spare switch on the dash and made it into a power button for the sub. That way if you don't want the bass on you can just switch it off.
Cheers man that is a great idea, I have a volume control dial supplied with the vibe mono and was thinking once the novelty has worn off slightly I would put it somewhere. I will will need to look into whether it will fit inside one of the current spare switch covers.
Today is the first day I get to drive bowser after three weeks of projects (another post soon), so I am very much looking forward to playing some loud music and feeling his power again.
