1 - 10 of 10 Posts
After looking myself I didnt see any how to's for this so after fitting mine today I decided to have a go a writing a how-to
Tools Required
T30 TORX screwdriver or socket
15mm socket and ratchet
13mm socket
13mm spanner
blowtorch (or in my case deodarant and a lighter)
jack
axle stands
Step 1
Jack the car up and support with axle stands - loads of threads on this so I wont go into details
Remove the 7x t30 bolts holding on the undertray and you will see this.....
Automotive tire Wood Grey Bumper Motor vehicle
Step 2
Undo the 15mm bolt holding the gearbox mount in then undo the 15mm horizontal bolt across the cast arm that attaches to the gearbox.
Undo 3x 13mm bolts holding the cast arm to the gearbox and remove.
The last bolt will need a 13mm spanner as its too close to the turbo hard pipe to get a socket in there.
Remove the unit from the car
Sculpture Wood Hand tool Art Brick
White Wood Font Line Art
Step 3
Push the new insert into the mount from the topside and you will have as shown
Helmet Cap Motor vehicle Hat Baseball cap
Triangle Motor vehicle Wood Font Automotive design
S
Step 4
The other bush has to be either pressed out or burned out. I chose to burn mine out then clean up the arm with some steel wool after
Wood Grey Revolver Bicycle part Gun barrel
Step 5
Insert the two sides of the purple bush then use the copperslip sachet provided and lubricate the inside well. The metal bolt then pushes in
Wood Grey Gas Table Circle
Step 6
Re-attach the two sections loosely with the 15mm bolt as follows
Gas Electric blue Font Motor vehicle Composite material
Step 7
Refit the mount back in but dont tighten any of the bolts till you have all of them partially threaded.
After that tighten all bolts.
Automotive tire Motor vehicle Hood Vehicle Bumper
Refit the undertray and tighten all 7 torx bolts
Job Done!
Tools Required
13mm socket
13mm spanner
jack
axle stands
Step 1
Step 2
Step 3
IMG_0904.JPGS
Step 4
Step 5
Step 6
Step 7
Job Done!
:cheers:
. Would you be so kind and give me a link for this kit . cheers :)
1 - 10 of 10 Posts
