1 - 9 of 9 Posts
Hi guys could someone tell me what the plastic tubing bit on photo connects to as mine has come off and is just flapping about,I only got car yesterday and when cleaning engine bay I noticed it cheers steve Car Vehicle Hood Motor vehicle Automotive design
Would I remove full length of plastic tubing and put bung where jubilee clip is mike,and where would I get bung mate thanks
If your just removing the pipe that go's from the scuttle to the bit by the inlet you'll be fine but if your thinking of removing the whole unit then you need the bung.
Sorry I've probably confused you by saying you need to block it off but most people remove the whole unit but had I read your post properly I would have seen you just needed to remove the crossover pipe piece
1 - 9 of 9 Posts
