1 - 17 of 17 Posts
hi all,i have a 50' samsung plasma 3d and could do with some advice on the settings:) as i keep getting a ghosting shadow around the objects on the screen ie people,cars fast moving stuff is there any way of getting rid of it as its really annoying and shouldnt really be doing it...i have played around with some settings but some stuff i dont know what they do
any info would be greatly appreciated
Ok, go into advance settings and adjust the white balance. Let me know how you get on.
what would be the best setting to put it on dynamic,standard,relax,movie?? i currently have it set on dynamic as this seems to give the best picture...well brightest
I see. What sometimes can happen is you get interference from the analog/digital ariel. The usual trick is unplugging them to see if it solves the problem.
Only thing I can think of is a crappy connection somewhere.
Graham - mk2 stage 3
This might be inherent on this model. Did you view this sort of programme before you bought the set? Back in the day this was quite common in some sets but I thought that now the technology had cured it.
1 - 17 of 17 Posts
