Hi all
Had anyone fitted the colour screen Parrot CK3200 to the ST ?
Wondered how easy it was and where you fitted the screen ? I have purchased the extra lead required.
Any info really appreciated!
Mark
I am just in the process of fitting the CK3100 which has the same wiring and is fairly straight forward if you remove the glove box to install the control box and routeing the wire's.
It can be a tight fit behind the stereo once all the cables are connected so is just a case of organising them away from the back of the stereo.
AS for the display I have put mine in the ashtray but it will depend on the height of the CK3200 because there is only 60mm to play with when the pull out part of the ash tray is removed.
There is a hole behind it feed the cable through which is handy also.
I will have a few more picture tomorrow when it get fitted back in the car
Thanks for the reply.
Think the 3200 is too high to fit in the ashtray so have to have a re think!
Just need to find out the correct and safe way to remove the soddin sat nav headunit!
Mark
I am not sure but it does look like it needs the removal key's for the top 2 slots but how else it is fixed I don't know
