This is common in cars that do short trips. It is caused by water emulsifying with the oil when it does not get hot enough to evaporate off. You only really need to worry if you find oil in the coolant water.
For every gallon of fuel you burn you get a gallon of water. That is why if you do mostly short trips you should change the oil and filter more frequently than the service intervals.
