1 - 3 of 3 Posts
UK 2005 ST
error code p0088
changed fuel pressure sensor (new), still code comes up after clearing
got OBDII live data says 633kpa which is about 90psi
All I can think is now fuel pump or because i've put E10 in it.
Suggestions? Or ways to check.
There are subtle differences between the oem Bosch regulators, you have to make sure you have exactly the correct part number, as there are only single digit difference’s.
1 - 3 of 3 Posts
