1 - 14 of 14 Posts
· Registered
QUOTE(Focus_ASBO @ 14 Nov 2009, 08:35 PM) <{POST_SNAPBACK}>Send Profile a PM or ring them, i have only seen one other (but there maybe more?) I am sure they will sort things out for you depending on how old it is?
Rick
is there any one out there who repair intercoolers it was only fitted last year pm"d gary and he says there demo car has done the same thing but is still ok personally id rather get it sorted in case it lets me down
· Registered
Ive had a customer ask me for advice about a bulging cooler as well. Though im not sure whether it was a code red one. Garys pretty clued up to what he is doing and if he says its ok to use then i would carry on. Though having something like normapply points to an overboost of some sorts or failure within the core of the cooler.
· Registered
We have also witnessed a handful of early intercoolers which the bottom couple of rails have expanded (including our own test demo car which has one of the 1st ones)
The initial batch of intercoolers had originally been tested to 2 bar however we discovered that the pressure spikes on sudden lift off momentarily exceeding this figure.
All subsequent batch's where uprated and tested to 3bar and we have not seen a problem since.
There is no danger of them bursting or loosing boost pressure - Our now 36k old demo car still has the original one fitted. -However the Germans have been swapping the handful of early ones under warranty
(we have to return the old one 1st)
· Registered
[quote name='wolfman' post='616120' date='20 Nov 2009, 01:49 PM']We have also witnessed a handful of early intercoolers which the bottom couple of rails have expanded (including our own test demo car which has one of the 1st ones)
1 - 14 of 14 Posts
