QUOTE(jamesmacc2008 @ 22 Dec 2009, 09:45 PM)
<{POST_SNAPBACK}>yeh i have heard, i was told to lower the radiator cradle and its only 4 bolts?
I seem to have the knack with it now - yep 4 bolts to drop the radiator cradle then once the ECU cover is off and you remove the ECU plus the wiring loom elbow and air intake scoop, you can pull it up out of it's rubbers, slide it over to the ECU side and swing it upwards and out. Tis tight but surprisingly straight forward.
Of course don't blame me if you find you have to refit it and can't work out how the hell to get it back in
