Hi Ford people's 🙂
Posting in miscellaneous as it seems the right place
I regularly drive about 3 and a half hours to see my squeeze down the road in old trusty... But the last run I did I noticed once I got on the motorway and started cruising at 80 the temperature gauge was sitting higher than normal at about 3/4, now I know from reading that this is a bit of a guess from the ecu iirc? However when I got home I checked my oil and coolant and found the coolant had gone down below the min level by about an inch, still a good bit in there but where's that gone?
I always check my levels before I go down the road and all was good before I left, I had not long had a service, and before the garage service I'd changed the oil and coolant myself a few months before, so good oil and good coolant
I topped up slightly on the coolant and it seems fine now, the temp goes back down to around half way driving at 60, am I just being paranoid with this coolant loss and temp?
With this cold weather over the past couple of months I've noticed when I boot it that there seems to be a more than normal whitish vapour from the exhaust.....surley not the turbo giving up? Just the cold air?
And nobody say HG 🤫
Anyone think I have an issue? Seems to run smooth enough and I've not noticed high temps other than the motorway, because I've done the bolt ons I'm slightly worried I've over stretched the engine, obviously more stresses there than stock
Pete
And nobody say HG 🤫
Pete
