QUOTE(MatST-3 @ 21 Nov 2009, 08:12 PM) <{POST_SNAPBACK}>hi all as some of u might have read i recently had my car stolen
but it has since been recovered but it has some damage to the oil sump. the question is its at a recovery garage at the moment and there is oil leaking out the bottom would this mean that the car wasnt ran dry of oil or would this just be what is left dripping out? ive been told that if the sump is damaged then the engine is goin to be
but if there is still oil leaking could this be a good sign that the engine is ok?
thanks
Did you actually check the oil level? If you did and it read ok, then is the oil clean or dirty like it hasnt been topped up recently. If that shows the oil is slightly dirty then i dout it ran dry. Start it and see what it sounds like is what i would do tbh.
thanks
