1 - 13 of 13 Posts
ive just bought an st and noticed that the oil pressure goes up and down when driving, when its sitting parked ticking over it sits just under 1/2 on the guage when driving along it sit about 3/4 and when u floor it it goes up to 5 the when u come off the throtle it drops back to 3/4 is this normal??
might just b a silly question??
thanks
QUOTE(irish st @ 8 Feb 2010, 06:29 PM) <{POST_SNAPBACK}>cheers stingy
just realised your from n ireland m8 me to ive got full stainless miltec exhaust including manifold and GGR induction kit? would u recommend a re-map? and who would u recommened to do it cheers??
FocusSTOC Nut&#33;
QUOTE(irish st @ 8 Feb 2010, 06:34 PM) <{POST_SNAPBACK}>just realised your from n ireland m8 me to ive got full stainless miltec exhaust including manifold and GGR induction kit? would u recommend a re-map? and who would u recommened to do it cheers??
remap definately mate. pm'd you details of mine.
you need to spend a tenner and join here mate its the st bible when you have full access
FocusSTOC Nut&#33;
QUOTE(stingy @ 8 Feb 2010, 06:45 PM) <{POST_SNAPBACK}>remap definately mate. pm'd you details of mine.
did you get the personal message mate.
QUOTE(irish st @ 8 Feb 2010, 05:44 PM) <{POST_SNAPBACK}>ive just bought an st and noticed that the oil pressure goes up and down when driving, when its sitting parked ticking over it sits just under 1/2 on the guage when driving along it sit about 3/4 and when u floor it it goes up to 5 the when u come off the throtle it drops back to 3/4 is this normal??
thanks
You're right.
Guys dont know if mines right. 1st thing in the morning when cold , It starts right up on the 5 drops off a bit, then drops down just under after 5 mins or so. Then its like what been said already, when the oil gets warm. Its the same in the evening after work at 6.30pm . only had the car 5 days , so not up to speed on the st after owning vauxhalls .Is its because the oils cold .
FocusSTOC Nut&#33;
QUOTE(mark 103 @ 10 Feb 2010, 07:58 PM) <{POST_SNAPBACK}>Guys dont know if mines right. 1st thing in the morning when cold , It starts right up on the 5 drops off a bit, then drops down just under after 5 mins or so. Then its like what been said already, when the oil gets warm. Its the same in the evening after work at 6.30pm . only had the car 5 days , so not up to speed on the st after owning vauxhalls .Is its because the oils cold .
when the oil is cold = higher pressure.
when its warm = less pressure.
once you rev the car the oil pressure will rise.
on tickover it will fall.
as long as its not in the red its fine.
QUOTE(stingy @ 10 Feb 2010, 08:29 PM) <{POST_SNAPBACK}>when the oil is cold = higher pressure.
Thanks stingy
1 - 13 of 13 Posts
