I have a blockage in the air intake system I believe, after leaving the car sitting for 3 weeks while I was away After the engine warms up the engine starts making a hissing noise. I had a little look about in the engine bay and found that the is a pipe coming out of the top of the oil filter housing to the top of the engine ( through rocker cover) had spilt,when moving that pipe about the hissing stops. (split open)
I've replaced that pipe but the noise is still there. I have now noticed a small oil leak from one of the gaskets in the rocker cover. I believe this is down to a build up of pressure somewhere. Ive lifted out the oil dipstick the hissing has now stopped.,but it now seems that the air is being drawn in from the oil dipstick. This would indicate a blockage somewhere. I was wondering if it is down to the oil filter housing being blocked and a replacement needed. Any ideas ?
QUOTE(ozzyb @ 24 Jan 2010, 07:28 PM) <{POST_SNAPBACK}>Thanks gardener
Will give ford parts a ring tomorrow and see what they are charging for this now
I paid £161 around 3 weeks ago but the VAT has gone back up since. The bill from Ford to fit it was £39 including VAT
