1 - 17 of 17 Posts
· Registered
First of all hello to everyone! I'm proud owner of ST225 for already month and a half but i have problem with oil filter housing or oil diapgrahm..
I noticed that the housing is so dirty from oil but the top of oil diaphragm is dry and clean but i also noticed a little vacum noise while opening oil dipstick when engine is running..
So my only question is what could cause housing to be so dirty from oil? And should i change diapgragm or whole filter housing?
· Registered
:unsure: You should have a small vacuum when you take the dipstick out thats totally normal and part of the PCV system. If the fiter housing diaphragm goes you get a massive vacuum that causes screeching noise when the dipstick is in. Yours looks like its blowing oil out of the plastic lid on the filter housing which can be a sign of too much pressure in the crankcase. Could be the pistons, piston rings or valve guide seals allowing pressure into the crankcase or the metal gasket between the intake manifold and the head. The gasket has reed valves in it that stop pressure getting into the system on boost but allow the vacuum when the throttle is shut. The reed valves can get bent or break allowing pressure into the filter housing. See pictures, the reed valves are ringed in red. Gasket is 9439 in the drawing.
Font Auto part Parallel Engineering Rectangle
Font Bicycle part Rim Auto part Automotive exterior
Automotive lighting Automotive exterior Font Auto part Triangle
· Registered
Thank you for information,that's why i was confused becouse i saw that everything around oil diapgragm is dry but didn't understand why is the filter housing so dirty..i will order the metal gasket for intake manifold and write back if it solves my problem!
· Registered
(y)I would also get a compression and leak down test done to rule out damage to the pistons and bores.
· Registered
(y)Actually before you do any of that take the plastic top off the housing, the big squareish bit. It just clips on all the way round so you can remove it if youre careful. Then run a bead of silicone sealer round the joint and put it back together. Let it set for a few hours and see if that helps. It can just be oil weeping out.
· Registered
2007 Focus ST3
:unsure: You should have a small vacuum when you take the dipstick out thats totally normal and part of the PCV system. If the fiter housing diaphragm goes you get a massive vacuum that causes screeching noise when the dipstick is in. Yours looks like its blowing oil out of the plastic lid on the filter housing which can be a sign of too much pressure in the crankcase. Could be the pistons, piston rings or valve guide seals allowing pressure into the crankcase or the metal gasket between the intake manifold and the head. The gasket has reed valves in it that stop pressure getting into the system on boost but allow the vacuum when the throttle is shut. The reed valves can get bent or break allowing pressure into the filter housing. See pictures, the reed valves are ringed in red. Gasket is 9439 in the drawing. View attachment 910757
I always wondered what those things were for,
· Registered
Discussion Starter · #14 ·
Soo update on the oil filter housing..i bought a new one and mount it but i still get vacum noise from oil dipstick and oil cap and the RPM slow down a little bit when i open it..so is that vacum noise normal or?
· Registered
When the engine is running open up the oil cap - if the pcv is functioning as it should you should feel like it is sucking the oil cap back in. When it is the opposite you would hear and notice the pressure coming out. When you changed the oil filter housing did you cleaned the conecting hoses too?
· Registered
Discussion Starter · #17 ·
I cleaned only the little one which is connected above intake manifold..but then it is normal becouse it is sucking the oil cap back in (y)
1 - 17 of 17 Posts
