I was driving along the M.40 at 65-70 m.p.h. when i hear a flapping type noise, i turn the radio down so i can try and work out where it's coming from. It seemed to be coming from the door hinge area (upper hinge). When i get home i looked at the hinge and found that the rubber strip attached to the door by small white plastic pegs was loose in two places, ie the pegs easily came away, so i spread a small amount of silicon sealant along the back of the rubber let it dry, and took the car back out and hey presto noise had gone. Just check that strip along the door edge next time you hear a strange noise from that area.
