I got to it this weekend with fitting the new forge actuator. Bit of a pain in the **** but a few banjo bolts out made things easier.
First off I removed all the obstructions, scuttle panel, crossover and heat sheild.
A bit of wiggling around and it was out.
Unfortunately the rubber hose that goes between the actuator and boost solenoid broke while I was trying to get it off the actuator leaving it about an inch to short.
Nowhere local has any 4mm vacuum hose, Halfords only had 3mm and 5mm so I've had to resort to Amazon in the hope it will be here sometime today.
Anyway I carried on fitting the new actuator and setting the pre load. I didn't get any pictures of this as I was already annoyed due to the hose breaking.
