I do have a 90° extension for the o2 sensor if it throws up the eml, but I never had the problem with the decat fitted (if that's what you're on about). As for the puma 4 branch I'm having to extend the o2 sensor wiring, but not sure whether to extend the sensor wiring, the ford wiring loom or make an extension harnes to go between the two.You got the same problem as me. Hope you get it sorted as i'm still trying to find a solution without using a small extension.
Ah i was on about the cat to manifold on the third picture. I've seen the size extenders so you can have 2" to 3".I do have a 90° extension for the o2 sensor if it throws up the eml, but I never had the problem with the decat fitted (if that's what you're on about). As for the puma 4 branch I'm having to extend the o2 sensor wiring, but not sure whether to extend the sensor wiring, the ford wiring loom or make an extension harnes to go between the two.
I've got the mot booked for next week, can't wait to get it back on the road again.Looks the same as mine, 2 mot so far and no problems 👍🏻
Mine was the same, once that decat was off the car and I had the blow torch on it I did manage to remove it. Still always better to have a new one.Mine needed a new sensor as it had welded itself to the original cat
Fire solves most problems 🤔🤔🤣🤣🤣Mine was the same, once that decat was off the car and I had the blow torch on it I did manage to remove it. Still always better to have a new one.
They have and are on the to replace list, as is a low level jack to replace the orange jack. The 3t sgs jack won't fit under the st.Those Axle Stands look as if they've seen better days!
The spacers, couldn't stand how it changed the handling. Its hard to describe but just felt fidgety.The OE brake setup looks much better and the bonus is you can ditch the spacers too.
What was it specifically about the E38 Brembos you didn't get on with?
Probably because they cause positive camber when turning, also the bumps from even minor uneven road surfaces get amplified through the steering wheel when the track width is widened. There is quite a lot of information available online and the negatives of wheel spacers invariably outweigh the positives.The spacers, couldn't stand how it changed the handling. Its hard to describe but just felt fidgety.
