QUOTE(ThcKid @ 15 Dec 2009, 10:43 AM)
<{POST_SNAPBACK}>I get a bit of torque steer now anyway
just had to concentrate a LOT more in the RS
Its a choice between the diff and the downpipe and sportcat....now thinking the extra power may be useless without the diff
Also, does it affect the weight of the steering i.e. make it heavier at all?
I've just had a Quaife fitted and I had all of your concerns.
There's no need to worry, get it done.
I would say that it improves the steering feel if anything, as for torque steer problems,
it's more a case of vastly improved steering feel and grip. Certainly no wrestling match.
I haven't seen any negative comments from those that have had it fitted, Gary at Profile fitted mine
they have plenty of experience with clutch/diff upgrades. (I would consider the RS clutch as well while it's apart)
You are right in that it's a question of balance, if you enjoy the twisties then the Quaife will
give you a lot more extra speed than the downpipe & cat. I think people shy away from the diff upgrade because it's not
viable to be sold on. If you are going to keep the car its well worth it & the sooner the better I say!
(I concur with Mr. Fishface, in that I find it works really well with the ESP too, despite rumour on the forum that it wouldn't)
I'm not convinced that wider track front wishbones will really help, it's still a McPherson strut with all of it's inherant camber change issues.
It probably aids turn-in and will alter the F-R balance because the roll resistance is changed, therefore it will be very different & most
will tend to perceive a difference as better when they've shelled out a lot of cash for it.
Hope that helps,
Jon
