Hi all,
Its been a while since i posted, but i am after a little help if you can assist?
I need to change the oil filter housing myself on my MK2 facelift. I have watched a couple of videos and read some forum guides and it is all straight forward...
1- Swing ecu over
2- Dip stick bolt and top bolt do from the top
3- Other 3 bolts do from the bottom
4- Slide off the hoses
5- Fit new as above in reverse
All i want to be sure of is: -
1- I do not need to drain the current oil in the engine?
2- I do not need to prime the new filter and filter housing with oil manually before firing the engine with it dry of oil?
3- I do need to lubricate new o rings/seal where the housing is mated to the block with engine oil?
Thanks in advance
Aaron
1- Swing ecu over
Thanks in advance
Aaron
