1 - 10 of 10 Posts
I running mob b plus but i need to drop to a lower map as the clutch is slipping quite badly with new tyres on the front now.
Im not going put DSCI map on so its between race plus or performance plus.
I don't know much about these two. which 1 give you the highest power (boost) or they just pretty similar.
cheers
QUOTE(boost junkie @ 21 Feb 2010, 03:39 PM) <{POST_SNAPBACK}>I running mob b plus but i need to drop to a lower map as the clutch is slipping quite badly with new tyres on the front now.
cheers
Try Race insted.
just been out and put race plus on. do get clutch slip still in 5th and 6th but not as bad as before. ill go stick race on then if its smoother.
What year is your
? Let me guess at 2007 ? There seem to be a dodgy batch of clutches on theses cars ...
My 55-plate has had no slip on any map
Dreamscience Flash
Weird these 2007 cars, we are offering the RS clutch upgrade now, £825 all in, mostly 07's interested, try Perf+ as it has a much flater torque curve mate until you sort the clutch out.
Come on the Tigers,
[email protected]
1 - 10 of 10 Posts
