thats what im doing to bud
going to use the RS ecu holder to relocte it out the way then run the biggest filter i can really get in the space behind the head light keeps it nice and high from water and should be a good airflow to it.
so ill measure up get the biggest filter a 90/45 deg bend boost hose to fit to the maf along with a bracket to hold the filter steady bobs your uncle, noise will be immense and will do the job only hassle with heat soak would be a hot day sitting in traffic but i don`t commute so couldn`t give a
bout that.
