1 - 20 of 21 Posts
Just installed the perf+ map with ds stratagem unit, wow the car has come alive! Cant belive i took so long to do it.
After a 20-30min drive i was playing with all the different menus on the device and i noticed that it was reading my oil temp at 150 degres! Surly this isnt correct, my gauges on the car were reading just under half way.
Which will be more accurate?
Mk2 RS 400
I think the Stratagem unit plugs in to the OBD port and therefore should be the most accurate of the two.
I have no idea what to do.
Does anyone else have the same unit? And does theirs work?
Is it degrees farenheit.....?
Why are you worried about the oil being 150o? I would have thought that was ideal tbh, as long as it's not over about 200 I would suggest it's normal.
As fair as I remember the ST doesn't have an oil temperature reading device. It uses the combination of other things like, air, water etc and uses algorithm's to give you an estimate. I might be talking utter
though.
Thats a good point. But when i was flicking through the menus it actually said "oil temperature too high" Thats what made me notice it as i wasnt paying to much attention, just having a quick look at everything.
though.
Correct. But I'm sure it's going to be 150 degrees farenheit, which is 66 degrees celsius which is about right maybe?
Mine usually sits below half way, I would say around 1/3 when it's warmed up. Wouldn't worry to be honest
though.
thought the gauges on top of the dash gives you correct oil temp???
The gauges on the dash are as accurate as Michael fish is with the weather, it's just a guesstimate which the ecu calculates from several different sensors.
The only way to get an idea of the temp of the oil ect is to get an obd scanner thingy such as a scan gauge or something like dash commander on your phone but even then I wouldn't be sure they are 100% correct
Got my Stratagem Ultra this week running the DSCI map at the moment, what a difference.
Noticed the oil temp warning before I even started the car. Having read up elsewhere, that reading / sensor (?) is designed to work with an external oil cooler kit, if you have got one fitted, otherwise it can be muted.
There is mention (in a round about way) in the description of the Dreamscience External Oil Cooler Kit, last but one paragraph.
http://www.dreamscience-automotive.co.uk/ford-focus-rs-mk2/performance-upgrades/850-oil-cooler-kit.php
Discussion Starter · #18 ·
Oh that all makes sense now! Thanks mate
If you look at the temps on your menu on the dash computer it will read about 140 degrees , not sure where it gets the temps from, any engine which runs over 101 degrees will go onto limp mode so it will be ok, on the DS ultra the engine temp is about right with the temp on the dash about 86 degrees.
http://www.dreamscie...-cooler-kit.php
I think you need an external sensor connected to the unit before it can read the oil temp?
1 - 20 of 21 Posts
