1 - 12 of 12 Posts
Lights on the ST are not that great, hard to see in dark, could do with improving any sugestions bulbs to buy etc??
guessing that you have got an st 170 then?alternative would have to be a hid kit www.hids4u.co.uk or if you can get a set of bixenon headlights out of another st 170.bulbs are just a waste of time regards Aaron
had mine set up properly a couple of weeks ago after fitting new headlamps and there perfect ,cant fault them to be honest ,maybe take car to a local garage and ask them to set them up for you.
are you sure its not an st 170 or st1
no its an st2
think they need set up as they are poor, going to fit an led sidelight though.
can you buy white bulb kits for the car eg number plate interior etc and where can you get replacement headlight bulbs if needed??
youl not be wanting to replace the headlamp bulbs if you can help it mate ,there just over £100:00 each in my local dealers ,very expensive bit of kit considering its just a fancy bulb .
The most frequent complaint we get is that they are simply set too low.
It's a 5 minute job to raise them a bit and you can do this by trial and error or get any garage that does MoTs to raise them to the maximum legal height using their alignment machine.
1 - 12 of 12 Posts
