I went to put the LED reverse lamp in that i got off Ebay and it doesnt work? Can anybody help? The orginal lamp works fine but LED doesnt light up, Ive got a 55 Plate St so should that matter? Im thinking that i need to reverse the wires around going to the lamp holder?
LEDs need to be installed in a particular way. If it doesn't work, take the bulb out, turn it 180 degrees and try again
EDIT - Hang on, I'm thinking of LED 501's. Might be different for the reverse bulb. Post a link up to the one you've bought.
Nope, mine was a case of plug and play. No way of turning them round in the reverse light if I remember rightly, either that or I got both that and the rear fog the right way round first time
Did your reverse light work before putting in the LED?
